jumping a polaris can u do it
Old Jan 2, 2000 | 02:20 PM
  #21
polaris250's Avatar
OK
Old Jan 2, 2000 | 04:19 PM
  #22
97TrailBlazer's Avatar
SCman..that's what i meant..it lands softly :-)
Old Jan 2, 2000 | 05:08 PM
  #23
polaris250's Avatar
YEAH TRAILBLAIZER SURE U DID
Old Jan 3, 2000 | 09:03 PM
  #24
BushHog's Avatar
The other day I was jumping my Sportsman 335 off some terraces and was getting two feet at times. But when I got home I looked around and found I had busted some bushings. Well, I replaced those;but when I swung the hub away from the quad after detaching the A-arms the shaft came out of the hub into the boot and I didn't know it until the bushings were replaced and I drove for a few miles. I heard some funky noises when turning so I took a look. Whoaaa! There was a shaft stickin' out of a torn boot and the right side of my quad was covered with grease and metal shavings. Anyways,I cleaned it up,got a 25 dollar boot that came with some stupid clamps. I put the one clamp inside the hub on the boot but I got a regular hose clamp that I could tighten and put it on the narrow end. Now I've put 47 miles on it and it's fine.(my two-three cents on the subject)
[This message has been edited by BushHog (edited 01-03-2000).]
Old Jan 3, 2000 | 10:56 PM
  #25
dominator's Avatar
Metal shavings comming out of your CV joint? Sounds like excessive wear from no grease. You did adleast replace the lost grease inside the boot?
skinnyr6
Aug 25, 2023 02:18 AM
randycraft24c
Aug 5, 2015 02:50 PM
jaime511
Jul 19, 2015 01:58 PM
Robinhood
Jul 13, 2015 09:13 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
