'HEEL CLICKERS INSTALLED'here are a few results!
Old Jun 27, 2001 | 10:46 AM
  #21
bubba1005's Avatar
Yes making the weights lighter will increase RPM's but the down side to that is you will be losing the benifits you gained with decreased belt slip. However if you add a stiffer spring you will also raise rpms more effectively.
What I was saying by adding the bolt to the heel is you can get an even faster shift out, provided you have the rpms to do it. Higher rpm's at engagment is a false sense of power. his bike may not wheelie in low like it did before. However he is pulling harder, and not just reving high and jumping into gear. The high rpm engagment is also hard on the bike especially with those big ol tires he has.
In my opinion I think he has the wrong pipe for his application.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
