hub oil
Old Jun 28, 2001 | 12:11 PM
hink250r's Avatar
How easy is it to change the front hub oil on a scrambler 4x4. Reason being, they are having trouble disengaging sometimes and i have read that changing the hub oil will help this. Any opinions??
Thanks
Old Jun 28, 2001 | 12:43 PM
MagnumMudMan's Avatar
hink
It is real easy. The simplest way is to remove the allen headed screw and turn the wheel until the hole is straight down and let it run out. The correct method is to remove the three torx bolts on the cover and remove the cover. Be sure not to damage the o ring upon installation. Hope this helps.
Old Jun 28, 2001 | 09:30 PM
OffRder15's Avatar
Be sure not to overfill it. When u fill it back up the fill hole should be at 4 o'clock.
