Front U joint loose on my Mag 500
Old Jul 16, 2001 | 12:51 AM
TrailBossKing's Avatar
The front u joint on one side of my 500 shakes a little when i move it with my hand. the other side is tight. i was wondering if the u joint could be out. it has about 3,100 miles on it.
Old Jul 16, 2001 | 01:52 AM
Traildog's Avatar
Sounds to me like you have a worn out U joint. For the kind of milage you have on the quad it's not too bad. It's not a good idea to ride until it has been replaced cos if a U join breaks the repair can be a lot more expensive.
Old Jul 16, 2001 | 12:18 PM
skidkid's Avatar
Make sure that it is the u-joint and not the yoke moving on the gearbox shaft. I had the same thing on my Xplorer, I thought it was the u-joint but when I isolated the play really well it looked like the shaft from the gearbox was moving. I took it to my dealer and when the mechanic saw it he said all it needed was a new roll pin that holds the yoke to the shaft. I thought he was crazy but I bought a new roll pin ($1.75) put it in and it is as tight as when it was new. It was easy to replace.
Old Jul 16, 2001 | 02:18 PM
walexa's Avatar
skidkid,
Which yoke was loose? My 2001 Xplorer 400 has the yoke on the pinion shaft (rear of the front gear box) loose. It has about 1/16" looseness, and my dealership said that was within specs. How did you remove the roll pin? With a small center punch, or one the same diameter as the roll pin? Thanks.
Old Jul 16, 2001 | 09:51 PM
skidkid's Avatar
Walexa,
Mine was on the shaft to the right front tire. All I had to do to change it was roll the quad until the roll pin was facing forward and I used a punch just smaller than the diameter of the pin to get it started out but after I punched it out about half way I drove the new roll pin in and pushed the old one out at the same time. It was alot easier than I figured. I also noticed just the slightest movement on the pinion yoke and as soon as it gets a little more I will replace that one to. Heck as cheap as they are I will probably just grab a couple of them the next time I'm at the dealers.
STLyamwar
Jul 25, 2020 04:44 AM
metal249
Jul 28, 2015 09:35 AM
carolinabomb
Jul 26, 2015 08:40 AM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
