Tips on oil change
Old Jan 28, 2000 | 03:42 PM
Ruffles's Avatar
Hi. I'm about to do my first oil change on my 99 SP500. The dealer did the first one at about 250 miles and even though it only has 330 miles on it, I hit a stick or something that came up thru the fram and bent the oil filter. Since I need to replace the filter, it gets new oil as well. Any tips or advice on how to do it? I have the service manual and plan to follow it. Is it easy to do or will I have to take it all apart? I plan to work on it tonight so I can ride it tomorrow. Thanks.
Old Jan 28, 2000 | 06:56 PM
Bill.Ciliberti's Avatar
Draining the oil is a snap.First,warm the engine. Than take off your left side cover.This will allow easy access to the oil filter.Spin it off,install the new one.The oil drain plug is in the front,behind the left front wheel.Remove the drain plug and let it drain out.Thats all there is to it.If you get into trouble,read you owners manual.It will take about 1 and 3/4 qts of oil to re-fill.Good Luck,===BILL
shimanok2
Jan 29, 2016 07:37 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
bigbear350quad
Sep 11, 2015 12:40 PM
cornermike
Sep 10, 2015 08:30 AM
Jason Campbell
Sep 7, 2015 02:25 PM
