What is the best chain grease
Old Jan 30, 2000 | 06:01 PM
Jerrod695's Avatar
What do you think the best chain grease is? How often do you need to grease your chain? This is a dumb question but i have never owend an atv with a chain. Where exactly do you put the grease?
Thanks Jerrod
Old Jan 30, 2000 | 07:31 PM
Kagey's Avatar
I am a big believer in Maxima's "Chain Wax" I had good results out of it , You just warm the machine up spray it on the chain and let it dry. I never replaced a chain as long as I was using it and seemed like I rarely had to adjust the chain. On an O-ring chain use a dry type lubricant or just a rust preventive lube like WD-40. Oils will attract grit which will grind away on your chain like sandpaper. Oh , Maxima products are in the Dennis Kirk Catalog and a lot of dealerships have it.
Kevin Gowdy aka Kagey 1999 Polaris Magnum 500
Old Jan 30, 2000 | 09:36 PM
SportKod's Avatar
I use the Chain Wax too. Ride your quad for 5 minutes to warm up the chain, when you apply the wax, the heat will pull it in between the rollers like soldering flux. I was told not to use WD-40 because it had a negative affect on the O-Rings, so I stick with the chain wax.
Old Jan 31, 2000 | 08:12 AM
Mike Chero's Avatar
SportKod,
WD-40 is all I use on mine now and my O-rings are fine. I've had no ill affects at all. Most pros (GNCC XC) use WD-40 too. granted they probably change their chains after every race or two, but all you really need is something to keep the rust off the chain.
Mike Chero 97 Polaris Sport 400L/ 97 Polaris Trailblazer 250ES
<A HREF="http://users.penn.com/~hal9000/mikeetta.html">MIKE & CELESTE'S ATV PAGE </A>
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
bigred20653
Sep 19, 2015 02:11 PM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
