What are the biggist tire for a STOCK sportman?
Old Aug 6, 2001 | 02:45 AM
MudStud's Avatar
What can you run in front? x26 x27? how about widtch? 9 10? with out spacers..
My guess is that the back is fine with any tire? corrct me if i am wrong.
Please help because i am going to buy tires and want the best size.
Old Aug 6, 2001 | 01:35 PM
BLH's Avatar
BLH
I'll tell you, I got new tires few moths ago. I took some bad advice and got 27 inch ones. Now I wish I had gotten 26 inch. I got for the front 27x10-12, on 12-inch steel wheels. On the back, 27x12-12, on the same rims. Now, when I got them and put them on… first ride they rubbed bad, every bump. I had to put in spring spacer, raise the front fenders and move the floorboards back about 3/4 of an inch. Now, it still rubs, but only on extreme bumps. With the After market rims, I didn't have any problem with the tie rods rubbing. But I don't know if you use the stock rims. If you want to go bigger without a lift kit, I don't recommend 27 inches. They do look good though. Check out my pictures.
My pictures
Old Aug 6, 2001 | 05:42 PM
ExtremeMudman's Avatar
26x10x12 front MAX, and they still will rub on bad bumps
28x12.5x12 rear
STLyamwar
Jul 25, 2020 04:44 AM
Ean
Aug 28, 2015 09:39 AM
Cantbuytime
Aug 17, 2015 06:33 PM
erntee61
Aug 9, 2015 02:54 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
