Silencer and pipe suggestions for Scram 400
I have a 2001 Scambler 400 2x4 and I am looking for a good silencer that doesn't require rejetting. For some reason I have not had any luck finding more than a couple for the 2001. Does anyone know what would be a good choice? I am looking at the MSA Spark Arrester but I want to make sure there are no other choices I should be looking at.
Thanks for the help.
96 to 01 400 scramblers and sports all use the same silencer, No re-jetting will be needed with just a silencer, If you want a spark arrestor you can look at HPD, Hotseat, FMF or AAEN, If not check out DG & RCR also, I use the DG ovallite with my HPD and really like it so far but Ill probably upgrade to the FMF arrestor next year when the funds allow [img]i/expressions/face-icon-small-wink.gif[/img]
You might also want to consider DB's. I run the FMF on the new HPD race pipe even on a pipe it's not too bad. Nothing against PSI, but I had almost that exact silencer, and there isn't much to the noise reduction. HPD has some new, moderately quiet designs. I have a hand polished Hot Seat Billet silencer I would probably let go for $90 including shipping. This is the new design with the CNC Hot Seat logo milled on the end.
KT
KT
MeadowlarkFarm
Nov 27, 2019 08:40 PM
