400 scrambler ignition?
Old Aug 25, 2001 | 05:24 PM
highoutput2cycle's Avatar
does anyone known how i can get the ignition upgrade from hpd?i saw in their kit that they change the coil,the wires,ignition box,plug...
not listed in the catalog tough...
thanks.
Old Aug 25, 2001 | 08:10 PM
Fasterthangas's Avatar
O.K.; I'll bite....
What kit are you talking about? Where did you get this info?
Old Aug 26, 2001 | 05:25 PM
modquad's Avatar
I agree with Fasterthangas. I had my quad up to HPD a week ago for some fine tuning. Daryl sells a non-resistor plugwire boot, and we re-gapped my plug down to .018 for the 14.5:1 dome. Dialing the timing back 2degrees with his new pipe, and that was it. That's all he has, and it works great!!!!
KT
Old Aug 27, 2001 | 10:27 AM
o k,i'll make dialing the timing back 2 degrees,i have the new hpd race pipe,that all i wanted to known,thanks.
Old Aug 27, 2001 | 03:29 PM
by the way can you tell the exact number of the timing curve,from what i've heard it is 25 degree and you bring back to 23 right?!
thanks.
Old Aug 28, 2001 | 02:39 AM
modquad's Avatar
Original timing is 23.5, you bring it back to 21.5. That's roughly rotating your stator 1/16 inch clockwise. If you've had your flywheel lightened ( timing marks ground off) you can pick up a Mr. Gasket 7" (I think) degree wheel, part #1570. That along with a piston stop, you can follow the instructions on the wheel for finding TDC, marking it, and finding 21.5 and marking it. Don't use an automotive timing light, not too accurate, you need to use one for a 2-stroke.
good luck
KT
Old Aug 28, 2001 | 04:58 AM
modquad's Avatar
By the way, timing is checked at 3000rpm with the engine cold. DO NOT LET IT WARM UP!!
KT
Old Aug 29, 2001 | 05:23 PM
i got the job done and it worked out great,thanks.
ultangler
Nov 30, 2024 01:35 AM
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
Matt123
Sep 29, 2015 01:29 AM
kbazzy
Sep 26, 2015 11:26 AM
