500 HO stuck in reverse
Old Nov 22, 2001 | 06:51 PM
luv4ironman's Avatar
A buddy of mind has a problem with his 2001 sportsman 500 HO . It is stuck in reverse. Any ideas what has happened? Has anyone else had this problem? I think it may be out of warranty.
Old Nov 23, 2001 | 01:17 AM
hal's Avatar
hal
Try adjusting your shift rods, the procedure is in your manual, it only takes a few minutes.
Old Nov 23, 2001 | 08:44 AM
uflg95's Avatar
Also check to make sure the bellcrank (the aluminum piece that connects the shift rod to the shifting fork shaft) is not bent. This is common.
Old Nov 23, 2001 | 11:30 PM
yellowHO01's Avatar
is the "shifter" in the low position? if it is, or even close, take the right side panel off, and remove the top of the gear select box,(has 4 screws) lift the assembly up about an inch or two, then put it back in , but move the shifter to the rev. position. this should fix your problem.
Old Nov 23, 2001 | 11:48 PM
kodiakkid's Avatar
He says it is stuck in reverse. So why would you ask if it is stuck in low??
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
r1pilot83
Sep 27, 2015 07:38 PM
Jackg17
Sep 26, 2015 09:30 PM
