Sprocket question...
Old Nov 27, 2001 | 10:19 PM
polarisrules44's Avatar
hey guys,i gotta question for ya.ok i want to change my sprockets so that i have more low end,but i dont want to loose any top end.what could i do to even every thing out.i allready have the rcr stage 1 kit.but dont know what else to put on to even every thing out .thanks for any and all of your info.also what do i change the front or back sprocket to get more low end and do i go up or down a tooth. thanks :mike
Old Nov 27, 2001 | 11:18 PM
Farmr123's Avatar
You want to either go with a smaller front sprocket, or larger rear.
The amount of torque gained will be proportional to the number of teeth changed.
For example going from a 10 tooth front to a 9 will give you 10% more power, and 10% less speed.
Going from a 20 tooth rear to a 22 tooth will have about the same effect.
Just figure out how many teeth you have on each, and how much gain you want, and figure from there. Just one tip, change only one sprocket, or if you do change both, do one, test drive it, then change the other. A 10 or 15% change will make a noticeable difference.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Dammar
Aug 26, 2015 07:12 PM
QuadCity
Aug 13, 2015 12:58 PM
