Sportsman steering problem
Old Dec 16, 2001 | 07:55 PM
ADPolaris400's Avatar
When I ride the quad on pavement at higher speeds the steering will rock back and forth. At slower speeds not noticable. Whats causing this? Thanks for any help.
Old Dec 16, 2001 | 08:08 PM
GE4x4's Avatar
Could be loose wheel or hub, or the tie rod ends. To check the wheel or hub play, lift the front end up and grab the tire and try to move it side to side then top to bottom. If there is play you will feel movement. The tie rod ends check for movement in any direction.
Old Dec 16, 2001 | 08:31 PM
Kuntry's Avatar
My 2000 sp500 does this as well. It has been flipped twice and rolled two or three times, anyway I believe that it could any one of a couple of things:
1. Out of round tires
2. Bent rims
3. Tore-in/out out of adjustment
4. or two much egg nog
Kuntry
2000 sp 500
26" Bearclaws
ETC..................[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 16, 2001 | 09:15 PM
jakyl's Avatar
add worn steering post bushing to the list
Old Oct 27, 2003 | 11:04 PM
camoman's Avatar
Default Sportsman steering problem
Believe it or not I had this problem and I needed to get my front tires balanced. Once that was doen the shaking was gone!
Old Oct 29, 2003 | 06:44 PM
Traildog's Avatar
Mine did the same thing, what I did was to securly support the quad on stands letting the wheels hang. Put it in 4WD and slowely bring up the speed while keeping an eye on the wheels. The wheel/wheels causing the problem will show them selves as the wheel/wheels will start to move up and down, as would a tire out of balance. I ended up having one tire replaced under warranty and my problem went away.
3quadbob
Sep 18, 2016 09:46 PM
moneyman01
Jul 11, 2015 08:50 PM
toonces
Jun 30, 2015 11:19 AM
Gimp
Nov 17, 1999 08:59 PM
