HSP billet cylinder head.
Old Apr 18, 2002 | 07:27 PM
Rockey's Avatar
<< Adam,
For some reason or another the one size colder spark plug works better with the higher compression heads. I think it has something to do with keeping pre-ignition doen to a minimum by getting rid of heat. I started running one in my quad last summer and the fan never kicked on once as opposed to the BR8ES I used to use.
The colder spark plug doesn't make the engine run cooler. It has more electrode material to sink the heat away and preventing it from becoming a hot spot in the engine. If this happens, you get preignition/detonation, which is more common in higher compression engines.
Old Apr 19, 2002 | 03:33 AM
Todd400's Avatar
If you are still on your stock piston you might want to wait untill you do a rebuild and put a wiseco in, The higher compression will likely eat your piston skirt quickly.
Old Apr 19, 2002 | 11:24 AM
modquad's Avatar
Like Todd suggested. Personally, I'd wait til you can get your cylinder ported/drilled for the girdle. Then also do the piston/head change at that time. Then get ready when you pull the trigger, 'cause you be flyin!!!
Ken
Old Apr 19, 2002 | 11:26 AM
adamnieman's Avatar
Todd400,
Yep...got the Wiseco piston. Blew a base gasket so the cylinder had to come off to replace it. Whoever owned it before me must of had some engine trouble because it had a .020 over Wiseco in it.
Anyway...I am going to buy the cylinder head and install Delta 2 V-Force reeds and spacer at the same time. I might as well since the fenders come off to install the head, the carb might as well come off too. Thanks guys.
Old Apr 23, 2002 | 09:10 PM
  #15
adamnieman's Avatar
Mike Chero,
I bought the HSP head and should get it in a few days. Do I need to replace my head gasket with a new one...the HSP head uses a head gasket..is it the same as the stock one?
Also, what is the torque spec for the head bolts? Thanks.
Old Apr 23, 2002 | 10:11 PM
  #16
Jack's Avatar
The HSP head works fine. The gasket is not problem with pressures up to 175 lb or so. The girdle is certainly not needed, don't waste $$$. The B8EVX plug works quite well with this setup. General rule with these heads is not to go with wild race-type porting. It's not needed and only causes problems unless you are in a win at any cost situation. Mid-range porting is all you need. You will get improved cooling ability and have no problems if installed correctly. I ran the 14:1 dome for 3 years with no problems at all. Whatever you run make sure you use the correct fuel. I believe you need to run 92+ with the 12:1 and 104+ with the 14:1.
Old Apr 24, 2002 | 12:00 AM
  #17
Mike Chero's Avatar
adamnieman,
Yes, you will have to get a new head gasket. It uses the same type as the OEM. Any Polaris shop should have one. I wouldn't reccomend using the old one. There are tricks you can do to the old gasket, but it's always better to replace it with a new one.
Just make sure you install the gasket properly. The gasket can be put on wrong and the machine could melt down.
Dewhound
Apr 20, 2017 02:25 PM
firsttimerider
Sep 26, 2015 01:49 PM
Alex G.
Sep 19, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
