How long should a belt last?
Old 06-07-2002, 12:26 PM
bdsomers's Avatar
Just wondering how long should a belt on a sp 700 last. Also what signs should I look for before replacing it. Do you guys carry a spare on extended trail rides? So far really enjoy the 700.
Old 06-07-2002, 01:11 PM
sbatzold's Avatar
If you ask Polaris, a life time[img]i/expressions/face-icon-small-smile.gif[/img] ya, right. You can measure across the top, not sure what it should be, also hour classing from slipping or on mine it started engaging at a hight rpm.
Old 06-07-2002, 02:01 PM
PolarisPower500's Avatar
A belt will wear over a long period of time. It gets narrower and may stretch. However, it can last a "lifetime". You won't get the best performance out of an old belt but it will still drive the vehicle at satisfactory performance.
Old 01-31-2006, 01:35 PM
gunman457's Avatar
Default How long should a belt last?
WOW
Old 01-31-2006, 03:11 PM
handycap's Avatar
I have the belt from my 1994 400L 2x4, it had 5600 miles on the belt when replaced. I keep the old one around for a spare for my 2003 400 Trailblazer.
Old 01-31-2006, 03:32 PM
wayout's Avatar
it realy depends on your riding habits,the use of low gear on hills helps also especially when you're going slow or when you're hauling something heavy ect. a clucth kit helps alot also, it puts more tension on the belt so you wont have to use low as much..
Old 02-03-2006, 12:28 PM
Browndog's Avatar
I have owned seven polaris's the 2 I have now 95 Scrambler and a new 800. If you want the best performance replace the belt once a Year. Even if it is not bad. Your top end speed will drop if you dont. Keep the old belt or a spar.
Old 02-03-2006, 01:20 PM
upnort's Avatar
Have about 1800 miles on mine. Pulling firewood, plowing snow, trail riding.
Old 02-03-2006, 01:24 PM
colt2245p's Avatar
Originally posted by: gunman457
WOW
didn't anybody notice the dates of the original thread gunnie's stirring the pot again!!!
Old 02-03-2006, 03:37 PM
wayout's Avatar
must check that from now on.........
Quick Reply: How long should a belt last?
