Survey: How many people had their fan/fan sensor fail on them?
Old Jul 11, 2002 | 06:34 PM
brent87LT1's Avatar
Temp sensor "switch" went out on mine @ excactly 1 year old. $50
If you hear the gritty sound coming from your fan, get ready to spend $150. When mine started doing this, it lasted another 6-8hrs, then died completely. I took it apart and it was FULL of mud. That output bearing DOES NOT seal out everything. I do quite a bit of water riding and my SP400 only had 75hrs when the fan was replaced.
Old Jul 12, 2002 | 02:15 AM
OffRder15's Avatar
Well, I just had a local auto electric shop check out my fan and they said it works flawlessly, so I guess it's my sensor. Time to spend $20 on a new sensor.
Old Jul 12, 2002 | 10:05 AM
walexa's Avatar
brent,
I should have elaborated more in an earlier post, but I was short on time. My first fan quit on me one day. It had been running rough beforehand. I found a replacement wholesale, and replaced the fan. I took apart the original fan, and there was crud inside the motor as well as the bearing. My second motor started making the rough sound, so I replaced it. Upon taking it apart, it was immaculate inside the motor.......water had just penetrated the outer seal on the bearing. Now, my 3rd motor is sounding rough, but I'm just going to run it. It has been sounding like this for about 4 months, but runs fine, so it must be just the bearing. I tried to replace the bearing on both the first and second fans with no luck. Apparently I distorted the housing when pulling the bearing out, and it wouldn't work when I got it back together. So, the seals on the bearing don't always keep everything out, but for me, 2 out of 3 is more than 50%.
Old Jul 12, 2002 | 01:40 PM
maximus's Avatar
you are not going to mess the charging system up like the guy said. i have been doing this for years on my expediton and my sportsman 500. no problem at all. this works great because you can just run it all the time until you come to some water. you can hook it up where you can still use your senser and still turn on the switch when you want to. but you are not going to mess up your charging system
Old Jan 11, 2007 | 10:39 PM
  #15
chikester's Avatar
Default Survey: How many people had their fan/fan sensor fail on them?
where can you find a sensor for $20, the only one I can find is from a dealer and they are $60????
Old Jan 12, 2007 | 11:30 AM
  #16
colt2245p's Avatar
we just replaced the fan on my brothers 01 500 last weekend. the exact replacement at the dealer retailed for $207.00. wow we went to the the local auto zone and got a universal 10" fan for $49.00. had to drill 4 new holes in the plastic to mount it. the original is a 9" but the 10" fits ok you might have to trim a little plastic off the shroud. the old fan ran a lot the new one runs only a short time. also even though we hose out the radiators after each ride from the front the radiator was packed pretty good on the back side. and whats the diff if you run a fan continuosly or the headlights continuosly?? however at night time it would be a strain on the charging system.
Old Jan 12, 2007 | 03:25 PM
  #17
onesavage's Avatar
i had my fan on the sporty lock up and cause a overheating(the wife still drove it back)*****
all i did was spin it and freed up but was noisey....dealer replaced it under warrenty
Old Jan 12, 2007 | 04:05 PM
  #18
BikKat's Avatar
Got a used 2000 Sportsman 500, about one year after buying fan sensor went out. About 3500 hours.
Steve
Old Jan 12, 2007 | 05:56 PM
  #19
x_scrambler3's Avatar
I have mot replaced a fan in any of my quads I have listed. or sensors. Here is a page to look at they have alot of parts listed that can be bought an a auto parts store
Polaris parts
Old Jan 12, 2007 | 06:04 PM
  #20
stendori's Avatar
Super Quad Patrol
I'm watching you!
just remeber if the fan runs while your in the mud its real hard on the fan and will kill the life of it.
