will it hurt to run bike if it stays below 150 degrees.
a cooler engine is a tighter engine...tighter means more friction..more friction means more wear....i remember my old 2-stroke yamaha snowmobile...lots more power just as i started it up...but many mechanics told me to NOT run it hard 'til it warmed up to "optimal" running temperature to avoid premature cylinder wear.
A cold engine is a loose engine......if anything. As metal heats, it expands, and the engine becomes tighter. The reason the guy told you to take it easy until up to operating temperature is to prevent a cold seizure.....not because the engine is tight when cold. Upon startup, if run hard, the piston will expand from heat quicker than the cylinder, and can seize. This is more likely to happen with a forged piston than a cast piston, due to the high silicon content in the cast piston. The silicon in a cast piston resists expansion more. It is fine to run a 2-stroke once the engine has reached 150..........it works well for me anyway. I have a digital temp guage that I use, and try never to run it hard until it reaches 150.
#15
Bearings! Bearings are chosen not only based on size, but on the operating temperatures. As stated before, hot metal expands, cold compresses. So bearings, which are are very precise, were chosen for running at a specific temp range. However in this case, I wouldn't be too concerned about it running too cold unless were talking about high HP, high rpm, etc...
Maximus, I'm not too sure how you hooked up the second radiator, but if possible could you put an inline valve so you can regulate the flow a little? Just a thought.
#16
#18
maximus,
Your temp sender is outside the head of your engine, therefore you should not shot off the flow to the second radiator. Your coolant flows through the second radiator before it goes back to the engine, and if shut off, there will be no coolant flow. You will overheat the engine with the valve shut, and you will never know it because your temperature pickup for your guage is mounted in a radiator hose. With no coolant flow, the temp sender will show very little rise.
Also, all this talk about it needing to run at 200 is not correct. My manual specifies that the overheat light comes on at 205. The fan kicks on at 185 and kicks off at 157, per my polaris manual.
#19
