Got my 2003 Scrambler 500 4X4 today
Old 07-19-2002, 11:56 AM
scramblered's Avatar
when i said the 2 stroke is a "hell" better i was just reffering to your first reply when talked about the "fun factor" and performance feels wich seem better on the 400,and on the 400 if you're not happy with the engine performances you'll spend LESS and get MOST with the 2 stroke scrambler for sure,in stock form there is no extra mph anyway...
you're right about maintenence factor as well on the 500,i'm not bashing the 500,it is a POLARIS and a very great quad,but as i seen so many guys buying the 500 traded it for the 400 later in the past,i was just remembering,congrats the scrambler are the most recreational atv on the market.
Old 07-19-2002, 12:59 PM
Scrmblerman's Avatar
Congratulations evan on your ’03 Scrambler. You are too funny. What is the differences between the ’02 and ’03 model? Lube/check your chain, check your air filter once in a while and grease it often. You will love that machine. I am happy for you. Be careful.
Old 07-19-2002, 01:38 PM
MadDasher's Avatar
Hey Guys I am new to Posting , Not reading the Connection. I have a scrambler I love it, Can you advise me on the things I should do after I ride it to make it last longer I dont want to make any misteaks with it. I would love to know whats dif between the o3 and o2 scrambys.
Old 07-19-2002, 03:25 PM
BUBASCRAMBLER's Avatar
Evan
You need to show us a picture of this 03 before you make it look like its 10 yrs old.
Also you have way more than 5 or 6 Grease Zerts
Front A arms @frame(1 on each side)
Lower Ball joints (1 on each side at strut)
......MY2000 and back Steering Shaft (1 upper, 1 lower)
Rear swing arm piviots (left and Right)
Rear Axle Bearings (On the housing)
4x4 models also have=
Frt drive shaft slip joint (1 right by Trans output)
Frt Drive shaft U joint ( atleast 2 or 3 Joints in shaft)
Frt half shaft inner joints (1 on each side)
I figure at least 14, Grease them often and they will last.
(Very inportant when in wet,muddy, and/or sandy conditions or after power washing)
  #15
Old 07-19-2002, 08:19 PM
stumpjumper400's Avatar
you forgot the steering stem. hehe (2 zerks) i also use a grease needle and put some in the tie rod ends.
  #16
Old 07-19-2002, 09:18 PM
OffRder15's Avatar
I saw the 2003 Scrambler today and it looks HOT in that blue plastic. I guess it was an early '03 because I heard that the Scramblers were supposed to get new frames.
The differences I noticed was the drain on the PVT housing, located on the left, rear part of it. It's easily noticed because it's a little red piece that screws out. Another difference is the plastic oil tank, yellow painted swingarm,and the new plastic and graphics. Looks almost exactly like the '02 Scrambler 400 X.
  #17
Old 07-19-2002, 11:20 PM
GregV's Avatar
I have a 2000 Scrambler 4x4 and love it, my wife rides a 2002 Scrambler X 500 4-stroke, she likes the colors so I guess I should just be happy with that. I do have a 2002 Raptor, that's my go fast bike. I didn't want to mess with my scrambler, other than adding some bigger, more aggressive Gator tires (see "photos" if you like).
My advice to you Evan:
(1) Grease often
(2) WASH IT!! Don't trash it and let it sit for a week packed in mud.
(3) Keep up with your oil changes.
The most important advice that I can give you, regarding your flipping/bending story.........
........KEEP THE RUBBER SIDE DOWN!!! Ha ha
Enjoy, you won't be dissapointed with your Scrambler.
  #18
Old 07-19-2002, 11:36 PM
evan's Avatar
Hey buba crawled around in the gravel and found a total of 11 nipples or zerks as you call them. Couldn't find any on the steering, had the front panel off and felt and looked around but still didn't see them.
1 on rear axle
1 each side rear swing arms
2 under bottom left panel, front drive shaft back u-joint and sleeve
2 front drive shaft foward u-joints
(2)1 each side front shaft to tire u-joints
(2)1 each side front A arms
Thats all I could find and I greased them. There was still lots there but because I was in water yesterday I didn't think it would hurt.
  #19
Old 07-19-2002, 11:44 PM
ScramblerX's Avatar
You can't find the ones on the steering shaft because it doesn't have them. Thats why Bubba didn't mention them. They have sealed bearings now.
  #20
Old 07-19-2002, 11:47 PM
ftwflh's Avatar
When greasing dont forget the tranny output shaft bearing it is hard to see and get to.
Quick Reply: Got my 2003 Scrambler 500 4X4 today
