Trailblazer Question(Hard to Start)
Some friends of mine havea Trailblazer that is hard to start. If you get it started it runs fine but has a bad idle. Have checked the spark,airfilter,fuelfilter and tonight will check carb and compression. Could someone tell me what is normal compression and what is the setting for the air or fuel mixture screw. When you try to start it it spins good but when you go to choke it it seems like the motor bogs but will not start. Any ideas will be appreciated.
Ronnie
Ronnie
