a-arm bushings
Old Mar 19, 2000 | 09:51 PM
suzukimd's Avatar
Has anyone had any trouble with there front left a-arm bushings? My brass bushing either broke off or was never there and know the plastic one is warped and falling apart. What I need to know is the procedure for replacing them. do I have to remove the whole a-arm or just the bottom bolt.
Please Help!!!!!!
Old Mar 19, 2000 | 10:18 PM
Blazer250's Avatar
That is how my '99 came, I guess I never noticed it before. I bought it used. It only had 10 hrs. on it when I bought it this year.
Old Mar 20, 2000 | 01:23 PM
MaineRider's Avatar
Had to replace bushings and spacers on 00' scrambler 500 but because my son hit a stump with the left front If the brass spacer is missing I would suspect the same on yours On impact the A-arm is shoved back crushing the brass Check to see if the inner rod is bent You can just unbolt from the bottom of the strut and then unbolt the a-arm from the frame (2 bolts) there is a tapped rod inside the a-arm quick easy fix 15 min.
Old Mar 20, 2000 | 05:20 PM
suzukimd's Avatar
Thanks for the info. I'll check it out tonight and see what happens. Thanks again
Old Mar 22, 2000 | 11:15 AM
suzukimd's Avatar
My rod was bent. Is this a common occurance because I wasn't any harder then the honda 300ex I was with and he had 0 problems!
Old Mar 23, 2000 | 12:17 AM
A400L's Avatar
Call HPD and order a set of their bronze bushings for $4.50 each.
Customer Service #1
May 15, 2020 08:46 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
cdstang
Aug 31, 2015 07:52 AM
