different carb
Old Aug 15, 2002 | 03:14 PM
Peeny's Avatar
will a 40mm mikuni carb from an h.o, fit a sp400? curious because it will give it more power wont it?
Old Aug 15, 2002 | 03:27 PM
xcrider's Avatar
You have to remember that an engine is an air pump. The amount of air is dictated by size of bore and stroke and what rpm. If you change nothing on the engine in terms of increasing the CC's or increasing the RPM a ton the larger carb will not do you any good and you will probably loose. The larger carb allows more air flow and is designed with the airflow in mind to pull the fuel through the jets. The 2 stroke vs 4 stroke thing also comes into play here also as far as amount of air flow through the carb.
Now back to your first part of the question. I don't know if it will fit or not. My guess is it will fit the intake but how the rest lines up?????
Old Aug 15, 2002 | 03:38 PM
Peeny's Avatar
so then what should i do to increase the cc's to be able to use the larger carb?
Old Aug 15, 2002 | 05:27 PM
mojave300ex's Avatar
Remember If you put a larger Carb on, you NEED the same ability to exhale as to inhale so it works properly, a good exhaust pipe combined with that carb will make a huge difference.
Old Aug 15, 2002 | 05:34 PM
Peeny's Avatar
so what kind of pipe would be good? that will fit the sp400?
Old Aug 15, 2002 | 06:19 PM
polarisman3's Avatar
The more air and fuel that you can pull into the motor the more power that you gain.....just like on snowmobiles how you bore out the carbs........thats really the only difference in the 500 and the 500ho.......
Old Aug 15, 2002 | 06:28 PM
Peeny's Avatar
so what do yall suggest, what kind of pipe and how big of carb? what will i need to raise up the power significantly on my sp400?
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
