cant go through the water.........
Old Aug 19, 2002 | 07:52 PM
stillslo's Avatar
it s a trail blazer....cant go throught the water faster than a crawl.
it cutsout and dies. i have greased all elctrical connections, plug, whats left? if i let it sit for 40 mins or so she slowly crank up!
Old Aug 19, 2002 | 09:17 PM
PolarisPower500's Avatar
My Scrambler began choking out in water a few months ago. It will rarely die but this pisses me off to no end. There doesn't seem to be a fix, no one has any idea.
Old Aug 19, 2002 | 10:39 PM
stuckinmud's Avatar
A friend of mine had the same problem with his 2000 trailblazer. As it turned out he had a few cracks in the bottom of his air box. He used silicone on the cracks and the problem was solved. I'm not sure if this was the real problem or not. It might have been coincidence and the real problem fixed itself.
Old Aug 19, 2002 | 11:59 PM
Bubba297's Avatar
I have a buddy that had the same problem with his 2000 Scrambler. He replaced the plug boot and presto! it was fixed. You can buy an aftermarket replacement end for about $3-$5. Just my .02 worth,Bubba[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 20, 2002 | 12:16 AM
modquad's Avatar
Do like Bubba suggested, the boot is a cheap possibility. When you install it, put a dab of di-electric silicon grease inside. Also, the protectant of electrical choice is CRC 2-26. It not only cleans electrical contacts, it leaves a lubricant film for protection.
The first thing you should do when you pick up your machine, is take off the airbox and seal that intake boot on it really good. Like it was stated earlier, a tube on silicon goes a long way.
Ken
Old Aug 20, 2002 | 01:03 AM
Every connection on my machine is covered with dielectric grease. Air box is always dry. Next time I water ride I will check the rev limiter box. I'm going to disconnect the black ground wire on the CDI so nothing can kill the engine except a spark short or sucking water.
Old Aug 20, 2002 | 01:09 PM
xcrider's Avatar
Try the plug boot. I have had snowmobiles that just by sucking up heavy snow dust will cut out. $3 boot and all is well!
Old Aug 20, 2002 | 04:36 PM
WarriorMadness's Avatar
I had this same problem on my sons Trailboss. My problem is it has a clamp on K&N open to the elements. I went to fast through the water and it sucked some in. Took a half hour to get it to start running right. ANyone got a stock airbox for a 89 TrailBoss??
This is your problem has to be.
Old Aug 21, 2002 | 12:14 AM
jmrpage's Avatar
i ride in the water all the time and the only time i had a problem with my scrambler is when the water came over the handlebars. duh . air box full of water ( duh i wounder why it stalled out ) . clutch case full of water ( duh i wounder why it wouldnt move ) . i had so much water in the clutch ( belt ) cover i had to take it off to dry it out . thats my only problem with water . can ride in water up to my seat without a problem .
Old Aug 21, 2002 | 10:59 PM
Sisyphus2k2's Avatar
My 2k TB had the same problem..hopefully the fix isn't as exteme as mine
I found out that the cylinder base gasket had a rip in it from Polaris..so everytime I went though the water..it splashed onto the engine..and it was sucking water vapor right into the cylinder
I found this out cause the Compression was low, not low enough to stop the poor bike, but enough to make me check it
Hope it isn't this..but maybe you should check
