2002 trailblazer NOT RUNNING RIGHT
Old Aug 24, 2002 | 08:53 PM
curb's Avatar
Took off the oil injector easy to do Now it is running rough at idle & is back firing thru the carb. If anybody has taken the injector off and had this kinda trouble HELP I mixed the gas before taking it off so it wouldnt run with out oil....
Old Aug 24, 2002 | 10:37 PM
talonhawk's Avatar
Did you plug the oil injection line that you remove from
the bottom or side of the carb with a rubber plug? That
might be the cause. I'll have to check in my service manual
to see what else it might be.
Old Aug 24, 2002 | 11:02 PM
RickRitter's Avatar
After resealing the *block-off cap* did it work correctly ?
It seemed as if you did everything correctly . You did not remove the carburetor so it is really unusual that the bike doesn't run right .
Please post the solution to the problem when you find it .
Old Aug 24, 2002 | 11:15 PM
curb's Avatar
Ive resealed it with gasket material & silicon & blocked off the oil line looking in the back of the carb should that sleeve come down all the way
Old Aug 25, 2002 | 01:42 PM
RickRitter's Avatar
The back edge of the slide is cut on an angle , it will look to appear 5mm above the bottom.
Old Aug 25, 2002 | 03:59 PM
curb's Avatar
got it running right. pulled the block off plate off again resealed it fixed it. very stbborn plate.
3quadbob
Sep 18, 2016 09:46 PM
AtvManiac78
Jul 11, 2015 03:20 AM
butcho4prez
Jun 23, 2015 09:30 AM
Bm400ex
Jun 22, 2015 09:16 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
