Measuring chain tension
Old Aug 28, 2002 | 10:58 PM
gonefishin's Avatar
Need advice, new to quads. Will this work to measure chain tension: place a straight edge from front to rear sprocket and measure between top edge of the chain and bottom of the straight edge. Should the tension be measured while pressing down on the chain?
Thanks in advance for the advice.
Old Aug 28, 2002 | 11:17 PM
brent87LT1's Avatar
With no weight on the quad, you should have 1" of free play in the middle of the chain. Grab it with two fingers and lift up and down to see the play.
Old Sep 1, 2002 | 09:02 PM
markshop's Avatar
Try 3/16 to 1/4 inch of play. 1 inch is way too much. Read the book or the sticker on the chain guard.
Old Sep 1, 2002 | 10:17 PM
gonefishin's Avatar
Thnaks for the advice. Book says 1/8 - 3/8 inches of deflection at tightest portion of chain. I don't understand if that means slack in the chain without pushing down on the chain or when you apply pressure to the chain in a downward direction.
Old Sep 2, 2002 | 12:53 AM
scramblered's Avatar
if you're riding hard,no play at all is just fine or just a very little cauze polaris linkage/chain loose is order of the day always when riding,it must be a check after each run,when using an aftermarket chain tensioner the task become solved longer about the chain deflection,it keep consistent tension as well...
Old Sep 2, 2002 | 08:46 AM
markshop's Avatar
Sorry your right 1/8 to 3/8. Measure the slack without stretching the chain. Its not that critical as the other poster said it loosens quite quickly. I just snug mine up because when i tighten the bolts it seems to pull it in a little and gives it a little play. Just dont let it get too loose. That spells disaster.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
raman8tor
Sep 20, 2015 07:35 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
