do you need any special tools to remove primary clutch???
Old Aug 31, 2002 | 01:18 AM
LOCOMOFO's Avatar
i am out in the garage wrenching my tranny out and i need to get the primary clutch off and it is not cooperating????
Thanks
Dave
Old Aug 31, 2002 | 01:25 AM
dillas23's Avatar
Do you mean your secondary clutch. I think the primary is connected to motor.
Old Aug 31, 2002 | 01:27 AM
LOCOMOFO's Avatar
yes i mean primary unless i can get that clutch housing off without taking off the primary??
Old Aug 31, 2002 | 01:32 AM
dillas23's Avatar
no, you do need special tools to get the primary off w/o breaking it.
Old Aug 31, 2002 | 01:55 AM
modquad's Avatar
Yes, you need a clutch puller for both the primary (engine clutch) and the secondary (trans clutch) your local dealer should have them for you to rent or borrow (case of beer helps in the thank you department).
Where abouts is Cedar?
Ken
Old Aug 31, 2002 | 11:00 AM
mastrblastr's Avatar
You can buy a puller bolt at Erlandson Performance. Click HERE and have a look.
Old Aug 31, 2002 | 02:30 PM
400fnSport's Avatar
Where's an easy way to do it without having the tool. Walexa told me this and it worked out perfectly. Find you a 2" trailer ball that is fine threaded. (Luckily enough I had one!!) Insert a 3/8" extension with a socket into the hole of the shaft coming out the primary clutch. Screw on the ball until you hit the extension, then take a pipe wrench and tighten on the ball. The clutch will pop right off without any problems. I've removed mine MANY times with this method.
Old Aug 31, 2002 | 11:44 PM
PolarisPower500's Avatar
Good idea 400fnSport. How do you take off the secondary clutch?
I might get a clutch kit for my Scrambler someday and would like to know as much as possible about these clutches. I've worked with this type quite a bit but never took them part for performance upgrades. After the clutches are off, what is the best way to replace the weights, spring, and bushings?
Old Sep 1, 2002 | 11:05 AM
LOCOMOFO's Avatar
the secondary clutch slides right off(at least mine did?)
same with my snow mobile,the socondary will slide right off.
Thanks
for all the info???
P.P cedar is about 45 miles north of the twin cities.
Old Sep 1, 2002 | 12:39 PM
modquad's Avatar
I've got a Hot Seat centering and alignment tools. Give me a shout and you can borrow them. I'll probably be running up to HPD's shop on Tuesday, we could meet somewhere.....I would want them back.....the Beagles will find you. hehe.
Seriously, they make installation, and perfect alignment REALLY easy. That rally you're talking about, is that the Wisconsin one that was plugged in Dirty Wheels? If so, wouldn't mind takin' in the drags.
Ken
