HELP !! how to change brakes-Y2KTBoss?
First time for brakes...
The back was easy..
On the front I have the caliper disconnected from the disk, but I can't see any way to slide the pads off. There is a hex head screw on one side but it doesn't seem to do anything...
I'd appreciate any help
The back was easy..
That hex screw is your pad adjuster.Make sure after you install the new pads that you turn the allen screw in until it lightly touches the pads,than back it out one half of a turn.Good luck,===BILL
OO Xplorer 400cc 4x4
If you want to come in second ''FOLLOW ME''
