Xplorer 400 , what clutch spring?
Old Oct 3, 2002 | 11:10 AM
AZXplorer400's Avatar
Bubba, did you get my PM?
Old Oct 3, 2002 | 12:44 PM
Bubba297's Avatar
Yes I did. I knew I should have brought it to work today. I will get it out tommorrow.Bubba
Old Oct 3, 2002 | 10:44 PM
Andy~G's Avatar
Im kinda late getting in on this one but thought Id throw my 2 cents in anyway.
Ive tried both the green and white and what Farmr123 told you is exactly right.
I went with the green first but it was too aggressive for my style of ridding. I like crawling over rock,logs,obstacles and stuff like that. With the green spring you really have to rev the motor before it engages enough to pull you out of a tight bind like that and that has to be murder on the belt.
I have the white one in now and for me..its perfect! You still get better acelleration from a stop but it also allows you to do the slow stuff I like to do without the extra strain on the belt and motor.
In a nutshell...
If you like to nail the gas and run like hell then you want the green one.
If you want a good all around spring that improves performance in all catagorys then you want the white one.
Andy G
Old Oct 10, 2002 | 02:33 PM
Default Xplorer 400 , what clutch spring?
Bubba, I got the spring. Thanks! I will ship out the EPI spring to you today or tommorrow.
Old Oct 10, 2002 | 05:15 PM
  #15
Mudracer300's Avatar
yes please post how you like it and stuf when you put it on i think i might get one ????
thanks
Old Oct 10, 2002 | 10:32 PM
  #16
ChrisTurgeon2's Avatar
Sounds like the white spring is the one to get!! I am trying to get the white spring from my polaris dealer. Is there a part number for the polaris OEM white spring?
Old Oct 10, 2002 | 10:45 PM
  #17
Andy~G's Avatar
I asked my dealer about the green and white springs and they had no idea what i was talking about.
Give Rick Ritter at RCR a call.
I got both or mine from him.
Andy G
Old Oct 11, 2002 | 11:42 AM
  #18
Bubba297's Avatar
Chris, tell your dealer you want a spring for a 2000 or 2001 scrambler 400, 2 wheel drive. the white spring was actually a stock spring in alot of 400 2wheel drive sports and scramblers.Bubba
Old Oct 14, 2002 | 11:24 AM
  #19
Well, I recieved the correct "white Polaris spring" from bubba the other day. Yesterday I installed it. Here's what I noticed right off. Initial takeoff pull has increased tremendously. In low, I can wheelie it with no problem, and in high the front comes up just slightly. Pretty good for a utilitly beast! It hasn't changed the engagement rpm drastically enough to affect anything I do in the desert. I will still be able to hit the most technical trails without looping the bike. As far as top end is concerned, I couldn't really test that because I don't have a speedo. Next time out I'll bring a GPS and see what it's doing at top end. I didn't think of it at the time... Thanks again guys for the help! Bubba did you get your EPI spring yet?
Old Oct 14, 2002 | 07:40 PM
  #20
ftwflh's Avatar
If you really want to see some gains match that spring with Aaen's blue secondary and it will be awsome.I really like that blue I have it on both of my bikes and it made a worlds of differance.Helps slow you down better on hills.
