Xplorer 400 , what clutch spring?
#22
Hey, the orange in EPI will give quite a bit higher engagement than the Polaris white.That could give some trouble if you stop on a hill then try to take back off. It will hit fairly harder and might give some trouble. The red would be a good choice as a replacement. It would engage a little lower but not affect the top end. If you have the blue/green right now, the red or orange would be a huge jump for you. I would stick with the white for a replacement. To help with backshifting and compliment the setup, go with what Ftwflh said and get the secondary spring as well. I run the HPD violet secondary, but I am guessing it would be real close to the Aaen blue. If you have the white already, then just get one of the others, or order both and experiment. Different people like different things. Like I said before, I like alot of engagement.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
cdstang
Aug 31, 2015 07:52 AM
