Scrambler 500 Mods??
Old Oct 2, 2002 | 10:39 PM
scrambled6910's Avatar
If any of you guys still happen to look at dirtwheels, this month they did an artical on the "hotseat" polarises. They only had good stuff to say. I still like HPD and Rick Ritter is good too.
Old Oct 2, 2002 | 11:29 PM
Bubba297's Avatar
Turboman, if it is just brand new, give it some break in time (not too harsh) and it will loosen up. The 2-strokes loosen up real fast, but the 4-strokes take some time. Just for instance, my neighbor's Cannondale Cannibal took about 3-4 weeks of riding before it really broke in right. And I mean it gained 3 bikes in a drag race just from loosening up!Give it some time first and change the first oil on time. A complete clutch kit would definitely be my first choice on any machine.Bubba
Old Oct 3, 2002 | 02:53 AM
evan's Avatar
If you tighten up the back shock (make it harder, mine came from the factory on the softest setting) it won't absorb all the torque and should come up a little easier. Screw the large nut on the bottom of your Fox shock to the top. It'll ride like a tank, but should be easier to pull up. Rode mine like that for awhile but it was to hard on this old back.
Oh yea it will have a noticable difference in power when it breaks in (about 4 or 5 tanks of gas, can't remember).
Also tighten the 2 torque bolts(2 each side) at the bottom rear of the gas tank, the ones that hold the 2 sections of plastic together they tend to fall out, mine did. And the cheap *** tie straps holding the air intake together(right below your left thigh) for the tranny come off and you can get water in your belt system a lot easier, get a proper hose clamp and put it on and it's reusable.
Other than those pesky little items I haven't had any trouble and I run the bag off mine as much as possible. Because hell that's what I bought it for.
Old Oct 3, 2002 | 03:24 PM
dario500's Avatar
I recently purchased a 2003 Scrambler 500 4x4 and it pulls the wheels up like nothing.From a dead stop I can punch it and it will come wright up.The power could use a little more for my prefrence but I am going to take care of that with some hop ups.
Old Oct 3, 2002 | 08:37 PM
  #15
2002scrambler's Avatar
dude if u want to go cheap and do wheelies put a white replace your blue clutch spring with a white one and change your 500 belt and put on a 700 sportmans belt u can tell the difference
2002 scrambler
white clutch spring
K&Nair filter
700 sportmans belt
Old Oct 4, 2002 | 12:57 AM
  #16
turboman's Avatar
2002scrambler, whats the difference between the 500 scrambler belt and the 700 sportsman belt?? thanks
Old Oct 5, 2002 | 12:09 AM
  #17
02Scrambler500X's Avatar
I replaced my belt a week ago and I can pull a wheelie really easy, I dont really like it cause I do trail riding and thats scary, I push the gas about half way and she'l go over and its all stock!
Old Oct 5, 2002 | 01:14 AM
  #18
buffalosoldier's Avatar
I used to be able to wheelie. Now I can't...is this because I need to replace my belt? Or would cleaning it with brake cleaner do the trick?
Old Oct 5, 2002 | 12:38 PM
  #19
wimot1's Avatar
how in gods creation do u think your 500 4x4 is 50lbs lighter than the 500 2x4 thats makes it 96lbs total i would like to know how u think you got this far i dont think its feesable {thank you for your input} hthdala@adelphia.net
Old Oct 6, 2002 | 08:33 PM
  #20
the 700 sportsman belt is just a bit shorter and when u get into the gas u can feel the difference
2002scrambler4x4
white clutch spring
700 sportmans belt
11 tooth front sprocket
K&N airfilter
runs 6.5 in 100 yard drags strip
