250 trailblazer strarts hard
Perfect compression will be 125-130 psi. Anything below 100 psi will start to run bad and below 80 psi it wont start at all. Did this just start when it got cold? If it did you need to rejet and adjust the airscrew. Use the choke till it idles by itself and let it warm up before you ride in the cold. Dont ride full throttle in the cold or you will burn up the piston. Will it turn over with the starter?
jrooker6
04-23-2016 07:36 PM
Scooter's Shop
23
10-22-2015 07:04 PM
