which epi spring is best?
Old Nov 21, 2002 | 11:04 PM
yoopermike's Avatar
Default which epi spring is best?
i had my dealer put an epi clutch kit in my sp700. he put in the purple spring and i couldn't even back up without the override button pushed. is this normal? the engagement seemed too high for slow trail riding so i told him to put in the yellow spring but instead he changed something else, secondary maybe? anyway, what do you guys suggest? It's brand new and i never drove it with the stock clutching so i don't know how different it is. thanks!
Old Nov 21, 2002 | 11:12 PM
2manytoys's Avatar
EPI red spring is a good one to use.It is the same as a Polaris white.This is the next one up from stock. Changing primary spring will give a higher engagement, giving you a stronger take off. Yes you will have to use the reverse button if the primary spring is changed. You can bipass the button if you dont like using it.
Old Nov 21, 2002 | 11:35 PM
yoopermike's Avatar
how does the yellow spring compare to the stock one?
Old Nov 21, 2002 | 11:52 PM
2manytoys's Avatar
Im not sure about the yellow. All i know is that the red is a little higher engagement than stock. Before my Trailblazer was modded i could not pull the wheels up untill i put the red spring in and it made a huge difference. Now that it has mods i have an HPD clutch kit. Either way i had to use the button.
Old Nov 22, 2002 | 12:04 AM
yoopermike's Avatar
i guess i'll have to learn how to make changes in clutching, then i can experiment on my own! thanks for the info.
Old Nov 22, 2002 | 07:21 PM
ftwflh's Avatar
Hey I have an EPI red primary and a purple secondary new in the bags iand would make you a good deal on them.
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
chuck1177
Aug 11, 2015 03:22 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
