is it safe????????????????????????????????????
Old Nov 24, 2002 | 06:18 AM
tb01's Avatar
Default is it safe????????????????????????????????????
is it safe to remove the air box for my trail blazer did any body remove it?
Old Nov 24, 2002 | 10:55 AM
StevieD's Avatar
if your going to do it, i would suggest getting a better filter, and DEFINETLY an outerwear. also. you will need to rejet your carb. if you do these two things, you should be fine
Old Nov 24, 2002 | 11:38 AM
talonhawk's Avatar
I don't think anybody makes a slipon air filter for you stock carb. I'm sure someone
else will know for sure. You can shorting the black air inlet tube, the one that hangs
down inside the airbox, by cutting most of it away. Leave about an inch. Then get a
K&N drop-in filter. This should help some!
Old Nov 24, 2002 | 01:36 PM
hoover650's Avatar
UNI Pod Filter........clamps directly to your carb for $11.99 , but for me I recommend the stock air box with lid vents and a K&N with outerwear
Old Nov 25, 2002 | 12:44 AM
dfischer's Avatar
Not to beat up on your idea, but are you thinking your your carb and engine setup can outflow your airbox. Not all that likley. I did pull the snorkle and rubber donut thingie from my srambler 400 as I thought that "might" be restricting me, but unless you're dealing with some mighty small holes, I'm not sure you're gonna see anything for your trouble.
Axl_Z
Mar 9, 2025 11:14 PM
Customer Service #1
May 15, 2020 08:46 AM
rgjackson
Sep 23, 2015 01:53 PM
carid
Sep 14, 2015 03:40 PM
toonces
Aug 13, 2015 01:48 PM
