Front right wheel not getting power
Old Nov 30, 2002 | 01:31 PM
Polaridoo's Avatar
Default Front right wheel not getting power
OK, I got it fixed. It appears the problmem might have been two fold. The first thing I noticed is that the gap between the armature and the sleeve / magnet was not right. I adjusted the sleeve and that made a huge difference - but I still noticed that the magnet was not holding the armature plate as well as the other side. I looked at the spring holding the rollers in the cage and this spring (for whatever reason) had quite a bit more tension than the other side. So, I very slightly pulled on the spring to give it to take a bit of tension out of it and that seemed to do the trick. After spending a long time looking at these hubs I have determined a couple of things. 1) I really like the simplicity and 2) you better have a good armature and the right distance between it and the magnet. It does not take a whole lot for that magnet to let the armature slip when things are just slightly out of whack.
Thanks again to all the help.
Old Dec 1, 2002 | 09:37 AM
500DUSE's Avatar
Good for you[img]i/expressions/face-icon-small-happy.gif[/img]
MikeyBoyesq
Nov 27, 2020 02:44 PM
txkevin
Sep 21, 2015 02:02 PM
Mphillips
Jul 2, 2015 07:20 PM
UPLou
Jun 7, 2015 09:42 AM
