Major Problems with Predator can't ride till fixed
I noticed a huge problem with the predators but I should make you all guess at what the problem is exspecially if your short.
Next Post:
When you lift up on the rear of the bike by the grab bar it's hard to get the rear tires off the ground cause your just lifting the suspension.
Next Post:
Called the polaris engineers and there is no fix.
Next Post:
My Dealer and his super geek mop boy came up with a great fix.
Next Post:
No, Elroy that's not right. "YOU ARE THE WEAKEST LINK, GOODBYE" lol
Next Post:
I'm the new Predator GOD, bow to me.
Next Post:
Only I know the answer and my Dealer and his mop boy.
Next Post:
Alright all alright, Elroy was right.
But you have to unbolt the rear grab bar from left to right one bolt at a time and flip the grab bar over to lower it and then bolt it back up left to right again one bolt at a time.
Removing the two bolts from each side at a time won't work, like Elroy said. LMAO
If you check out my Gallery you'll noticed my dealer did it to mine cause I'm to lame to figure it out myself. (My little 6 year old cuz mentioned something about the rear bar a week ago, I forget it didn't make since)
I also noticed when you put the bike up on the rear grab bar (with Mom and Dads help) it sit's at about the same angle as a 400ex, not quite as steep as before. Might not be as good in role over protection though.
Next Post:
I'm God
P.S. Elroy is "The Man"
Next Post:
Next Post:
Next Post:
Next Post:
Next Post:
Next Post:
Next Post:
Next Post:
I'm God
