I Have a TON of Pred quest!
Old Jan 16, 2003 | 02:18 AM
  #21
ProXPredator's Avatar
Default I Have a TON of Pred quest!
SCOTT, how well does that type of filter protect against water and mud kind of situations? I found another site with the filter and outerware for $34.00. I thought that was a really good deal, let me know and thanks again!
Old Jan 16, 2003 | 03:35 AM
  #22
modquad's Avatar
If you do go without the airbox protection, make sure to use a water resistant outerwear. The stock Predator tires work surprisingly well when you ride on a groomed ATV trail (that's groomed snow) You can air down just a bit, to help traction too. I could be wrong, but doesn't Rath offer different hubs for the different bolt patterns.
Ken
Old Jan 16, 2003 | 12:08 PM
  #23
Scotts88's Avatar
SOO..could i just go with a set of 21" or 22" tires without changing any sprokets and get a bit lower gear & be better in the snow/mud??
Old Jan 16, 2003 | 12:36 PM
  #24
wilsonoo's Avatar
Hay proxpredator, what site did you find the filter and outerware for the 34.00, thats a good price I,am look for different filter for my predator. thanks
Old Jan 16, 2003 | 02:29 PM
  #25
GE4x4's Avatar
Scott
By going to taller tires, you will be higher geared not lower.
Old Jan 16, 2003 | 03:08 PM
  #26
WILSONOO - That web site that I found was http://deroucheyracing.com/productde...=ProductNumber and the part number for the K&N Filter is RU-1770 (88-000 thier part number and 88-200 outware their part number).
Old Jan 16, 2003 | 03:29 PM
  #27
modquad's Avatar
Hot Seat also carries the filters/outerwears. That would be supporting a Polaris performance shop too.
Ken
Old Jan 16, 2003 | 05:06 PM
  #28
Scotts88's Avatar
Crap..so to use the bigger tires i'd have to go with what sproket??
Old Jan 16, 2003 | 05:29 PM
  #29
GE4x4's Avatar
Scott
Stock is 14/37 with 20" rear tire. So if you were to put a 22" tire on, you would have to drop the front one tooth, or add 3 to the rear. That means you could have 13/37 or a 14/40 with 22" tires and still have stock gearing. But i think the stock gearing is a little high now, so if I was going to put on 22" tires myself, I would have a 13/39 or 13/40 gearing.
Old Jan 16, 2003 | 06:58 PM
  #30
Predator03's Avatar
Hey WILSONOO and Prox,
Actually, the Deroucheracing site you gave is where I found Hyper racing. Derouche is like a vendor post, where you can see all kinds of different products. You actually buy the stuff from the vendors listed. So if you go to Hyperracing's website, that's where you'll order from.
I'm real happy with the service. Only took a couple of days from order to ship. Can't beat that.
Scott
