need REAR axle removal help ON 500 HO
If your replacing the complete rear axle it's simple. Use a prybar between the trans an the inter joint an it will pop out. Sometimes you have to use a prybar on both sides. Look at your new one. It has a snap ring on the end thats what holds it in. Jeff
