42mm tmx carb vs 38mm tmx carb
Old Jan 29, 2003 | 03:27 PM
scramblered's Avatar
Default 42mm tmx carb vs 38mm tmx carb
you will just replace pistons with mikuni's tmx 38 and 42mm carbs or even worse:crank,the pwk 39 is better,good torque,great top end,easy to fine tune.if you're intend to run the stock airbox a k&n air filter or something similar is in order to fit well,instead the carb fit best with a filter charger directly without airbox...
Old Jan 29, 2003 | 11:36 PM
Armor's Avatar
Thanks to all of you guys !!! I know what to do now... get a 39 pwk carb ! Thanks again !
Old Jan 30, 2003 | 09:44 PM
2002scrambler's Avatar
the 42 mm flatside carb will fit your scrambler but u will have to drill 2 more holes in your airbox to move it closer to the carb
2002scrambler
k&n airfilter
42mm flatside carb
hpd pipe and silencer
shredder tire
alloy nerf bars
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
