How many discs came in your WB "Pure Polaris" Predator pipe?
Old Feb 10, 2003 | 05:10 PM
Rob4092's Avatar
Default How many discs came in your WB "Pure Polaris" Predator pipe?
I am trying to figure out how many discs are installed in a stock, out of the box, WB "Pure Polaris" Silencer?
Do they include any spare discs in a plastic bag that are separate from the pipe? If so, how many?
Old Feb 10, 2003 | 05:13 PM
Firehawk1970's Avatar
I believe my buddy got 8 with hi sbut I do know he got no spares...
Old Feb 10, 2003 | 05:39 PM
Rob4092's Avatar
Mine came with nine installed in the silencer. The instructions say "No jetting" is required from the box, but I want to make sure nine discs installed is "out of the box."
Anyone else?
Old Feb 10, 2003 | 06:04 PM
brent87LT1's Avatar
Nine.
Old Feb 10, 2003 | 06:18 PM
Rob4092's Avatar
Thanks Brent!
Did you re-jet your carbs with all nine discs installed?
Did your silencer come with any extra discs?
Old Feb 10, 2003 | 06:20 PM
truckracer's Avatar
Are you guys sure the ninth one you are counting is a disc. The solid end piece does not count.
Old Feb 10, 2003 | 06:22 PM
SP700RACER's Avatar
Rob, they come with 8 disc and a spark arrestor installed. Run 5 disc and the solid back plate. no jetting is required unless you run a hi flo filter or change the airbox.
Old Feb 10, 2003 | 06:53 PM
Rob4092's Avatar
I use my Predators in Mexico at sea level.
The temperatures can get hot and humid, nut never below 60 degrees.
The airbox and jetting is stock.
Considering the above, can I run all eight discs and not damage the engine?
Old Feb 10, 2003 | 07:26 PM
SP700RACER's Avatar
Rob, the reason for 5 disc is the stock head pipe is to large, you have to take out some disc to get proper back pressure. sounds weired but it works. I tested this theory at the drag strip, it does make a different.
The thing slowed down when i opened up the exhaust. Gary @ superbike shops discovered this info on the dyno.
Old Feb 10, 2003 | 10:00 PM
Rob4092's Avatar
Will I hurt anything if I leave 9 discs in without re-jetting? I like the loud sound!
