1996 Magnum 425
1996 Magnum 425
I think the 1996 models had a cable driving the speedo. My first guess would be that the cable is broken. Pop apart the handlebar pod. You should, with a little effort, be able to unscrew the cable going into the back of the speedo. Get it where you can see the end of the cable. Now drive slowly. If it doesn't turn, try pulling the center part of the cable out. My guess is it will be frayed/broken. If it looks good, it is probaby the drive gear.
Farmr
Farmr
09-09-2015 06:57 AM
