CV Joint Boot Replacement
Old Mar 30, 2003 | 01:12 PM
Farmr123's Avatar
Default CV Joint Boot Replacement
When you get the boot slid off, wipe off the grease real good. You will be able to see (barely) a little snap ring in a recess of the CV joint, where the driveshaft goes into the joint. Pry the ends of this snap ring APART, and you will be able to pull the axle out of the joint. With the axle out, you can replace the boot, leaving it slid back on the axle a ways. Re-install the axle into the joint, being sure the snap ring catches the groove in the axle, with the tabs of the snap ring leaning out towards the shaft. The shaft SHOULD be tapered well enough for the end to go through the snap ring without prying it apart upon re-installation. Now grease everything up, slide the boot into place, and tighten the clamps.
That should be the only tricky part. Dis-assembly and re-assembly of the A-arms and such should be pretty straightforward.
Farmr
Old Mar 30, 2003 | 01:14 PM
NCScrambler's Avatar
Well, I thought sometimes pictures are worth a thousand words, so... but yeah Farmr explained it to a t. I still got the pics if you want them.
Old Mar 31, 2003 | 12:03 AM
Folger's Avatar
Thanks for the instuctions Farmr. I private messaged you for the pics and what not NCSrambler. I can still use all the help I can get. Thanks. I'll give 'er a look-see tomorrow before work. Later.
Old Apr 1, 2003 | 03:02 PM
Folger's Avatar
Well I got 'er fixed before work yestrday. Thanks for all of the help. Farmr, your instructions were right on the money, thanks. You guys saved me a decent chunk of change. Just got back from a little muddin' with one of my buddies, with his new Arctic Cat. Everything seemed to work fine on mine. Nice to have it fixed, finally. Thanks again.
Old Apr 1, 2003 | 05:46 PM
  #15
That is good to hear Folger, sorry I was late getting those pics to you. But like you said Farmr described it to a T so....
Old Apr 1, 2003 | 10:36 PM
  #16
Farmr123's Avatar
Glad to help. Someone helped me out with that sort of thing when I was starting out, just passing it on down.
Old Sep 11, 2005 | 02:25 AM
  #17
lanmitch's Avatar
i am attempting to remove the front cv joints to replace the boots on a 2005 sportsman 700. Do you have any pictures or suggestions to help?
\Thanks
toonces
Jul 28, 2015 01:58 PM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
TLC
Jul 25, 2015 02:24 AM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
