What are you running in Pred with...
Old Apr 6, 2003 | 02:30 PM
Firehawk1970's Avatar
Default What are you running in Pred with...
Hey guys,
I have the E-series pipe. With stock filter ran great but when I added K&N yesterday was running a little lean. Bumped up to 160 main and runs awesome but a couple of times when I came to a stop after running hard ( I mean 3/4 throttle to idle quickly)itshuts off. Do I need to adjust something else?
Old Apr 6, 2003 | 02:53 PM
modquad's Avatar
I"m running almost the same setup, but added 5 (probably drilling for the 6th today) Univents along with the K&N. I drilled out the pilot screw plug and turned it in 1/4 turn, just to be safe. I need to spend some time out checking the jetting, but sure runs good. Are you running all the discs along with the quiet core and end-cap?
Old Apr 6, 2003 | 07:33 PM
vilnrk's Avatar
try moving the clip on the needle down (rich), it maybe a tad lean on the needle, since the K&N.
turbo bobby
Old Apr 6, 2003 | 10:30 PM
scooterpred's Avatar
fire hawk whats your elevation? i have wb slip on also was thinking of adding kand n talked to my dealer yesterday he said not to rejet im at 6000 ft bike runs great now havent done anything but the pipe when i go to the dunes its about a 1000 ft lowers still runs great you think i should rejet with k and n how did you notice it was running lean?
Old Apr 6, 2003 | 10:53 PM
little backfiring/popping slight hesitation...I am in SC at 0-200 ft above sea level. Runs great now except for isolated times shutting off. Went to mud run and the Geckos aren't kicking it for the drags. Probaly will see if I can sell them at Snakehunt. Gonna try just straigtht paddle.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
