Scrambler Rebuild!
OK the oil plug for the counterbalance is.... Take the middle skid plate off the bottom of the atv, you will see the starter ok looking from the front of the atv toward the back, the plug will be directly behind the starter in the middle of it. The plug to the right is the crankcase, the one to the left is the recoil housing, you want the one in the middle. The plug right beside the starter to the left is the starter pinion drain plug. Good luck, hope this helps.
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
