Trail Tech Magnetic bolt question.
Old Apr 21, 2003 | 12:13 PM
TLDPredator's Avatar
Default Trail Tech Magnetic bolt question.
I will be installing my Trail Tech Setup on my Predator soon.
Can I just use a breaker bar to losen the brake rotor bolt with out heating it?
I still have to look at it to see if I have to remove the hub first. Hopefully I can just make the bolt reachable and leave everything else intact. [img]i/expressions/face-icon-small-smile.gif[/img]
Thanks in advance.
Old Apr 21, 2003 | 02:12 PM
Farmr123's Avatar
Polaris uses threadlocking compound on the brake rotor bolts. It is possible to break them loose without heat, but heat helps tremendously. You don't have to get it real hot, just hot enough to steam a little to soften the threadlock.
Farmr
Old Apr 21, 2003 | 02:33 PM
Thanks!
I better look into some Thread lock to put on the new bolt.
Old Apr 21, 2003 | 05:01 PM
modquad's Avatar
TLD, watch the torque also. I normally run the bolt in and out a few times to distribute the loctite evenly.
Old Apr 21, 2003 | 09:08 PM
That's a good reminder Modquad!
I see that I can get directly at the bolt without any hassle. [img]i/expressions/face-icon-small-smile.gif[/img] Now I need to pick up some locktite so I can get it done. Hope I can find my propane torch.
What color Loctite was it I needed. I swear it's been 7 years since I sold the stuff. [img]i/expressions/face-icon-small-smile.gif[/img]
Ramman1
Aug 11, 2022 01:53 PM
carolinabomb
Jul 26, 2015 08:40 AM
maxjung
Jul 23, 2015 08:37 PM
skeets44
Jul 17, 2015 01:04 PM
Shifts
Jul 3, 2015 07:59 AM
