oil block off
Old Apr 22, 2003 | 12:32 AM
tb2000's Avatar
Default oil block off
I was reading a post about using silicone on the block off plate to seal it. Is this a must? Also, the rod that fills in the hole before the cover goes on was rattleing so I took it out and just put the plate on. Does that have to be in the hole. Thanks for any answers.
Old Apr 22, 2003 | 01:19 AM
modquad's Avatar
You're talking about the 250? If so, I believe the plug needs to be in there to maintain the designed volume. Give the post time, someone with one will chime in.
Old Apr 22, 2003 | 07:29 AM
duneaholic's Avatar
I have the 400 and I used the wrong kind of sealant and it leaked out everywhere. I got a high temp silicone and actually just got through sealing it up last night. I'm pretty sure that it sealed off this time. I think I talked to a guy name mike at HPD and he said that you have to have a SEALANT to seal it off or it will leak. I don't have the rod that you are referring to but I would leave it in if they tell you to. Hope this helped.
ReconBayou
Oct 31, 2022 05:37 PM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
nastyblaster100
Sep 13, 2015 01:19 PM
John Reed
Sep 9, 2015 03:46 AM
