/Rev Limiter Bypass Instructions
Old May 6, 2003 | 06:31 PM
POO's Avatar
POO
Default /Rev Limiter Bypass Instructions
Reverse Override/Rev Limiter Bypass Instructions
THESE INSTUCTIONS WILL NOT WORK ON THE 04 MODELS. I AM WAITING FOR SOMEONE TO SEND ME A 04 WIRING DIAGRAM SO I MAY PROVIDE INSTUCTIONS FOR THE NEW MODELS.
Polaris has incorporated a safety feature on all their 4wd models. This feature, which is operational all the time when reverse is selected, will limited engine power and cut out the front wheel drive unless you push the "override" button.
One of the main reasons you would want to do this mod is because when you get stuck and the only way out is reverse, it is impossible to pull the ATV backwards while applying throttle AND pushing the override button. It is also very helpfull when you use your ATV to plow and need 4wd every time you back up with the weight of the plow hanging off the front.
This mod will give you 4wd and full power when in reverse without having to push the override button. This is for all Polaris Sportsman models with the new style speedo (2003) and Sp700, 02. Continue down below for pre 03 model instructions.
The problem with the new style, is that the function button for the speedo is combined with the override button and it is not as straight forward as the old style speedo. Doing it this way everything works as it should exactly the way it did before the mod.
The nicest thing about this mod is that you do not need to cut any wires or drill any holes.
You will need to purchase a standard 4 pin, 12v relay, 4 pieces of 16 gauge wire about 8" long, 4 female crimp on spade connectors(for connection of wires to relay), and 4 wire splice connectors.(they are usually blue and you simply insert the wires and squeeze with pliers, then fold back the protective locking cover)
Open the pod and locate the wiring harness coming from the speedo.
Relay terminal #30 connect to Polaris brown wire
Relay terminal #87 connect to Polaris wire gray/orange
Relay terminal #86 connect to Polaris wire red/white
Relay terminal #85 connect to Polaris wire purple.
Use dielectric grease at all electrical connections to prevent corrosion in the long run or even better, liquid tape.
To test, simply put it in reverse with the engine running, if the speedo flases the word "SLOW" (just like it did before the mod, when you pressed the override button) you did everything correct. Enjoy
__________________________________________________ __
Pre 2003 and almost all models that do NOT have the combined override/speedo function button.
Trace wires from the override button (gray/white & gray/orange) Cut the gray/orange and tape up both ends. Cut the gray/white and tape up the end which goes to the override button. Connect the other end of the gray/white to the red/white (ignition supplied 12v) You will also need to trace the purple wire which comes from the handlebars and simply cut and tape both ends. Done deal.
IMPORTANT
If your wires are different colors than the ones I mention. Post a new topic and I will gladly figure it out for you. Polaris has been building quads since 84 and I cannot possibly know the color schemes for every model/year.
Joe454
Nov 20, 2020 01:19 PM
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
