engine ice
Old May 7, 2003 | 08:42 AM
99blueblaster's Avatar
Default engine ice
Been thinking about running engine ice in the Predator. I already have the radiator scoops which do help alot but summer is getting close and we do alot of slow woods riding. My question is does anyone know if you can run it in the winter time? It has anti--freeze capability up to -26 I believe but am worried about it making the motor run to cool in the winter. What are some others opinions.
Old May 7, 2003 | 08:51 AM
CED's Avatar
CED
Default engine ice
I don't think it will be a problem,i've been running it for 2 years without any heat related problems.I also have a 2 stroke,but i don't think it makes any difference.Hope this helps.
Old May 7, 2003 | 09:01 AM
scramblered's Avatar
Default engine ice
i think you should drop some redline water wetter in that predator,at the right mix,this stuff worth the test,it doesn't cost much too...
Old May 7, 2003 | 09:55 PM
nccracing's Avatar
Default engine ice
I dont want to sound stupid but...What is engine ice? Is it an addative or an antifreeze? Thanks
Old May 7, 2003 | 09:57 PM
pudljumpr's Avatar
Default engine ice
I would run the ice or water wetter for the summer, but when fall comes around, switch it back cause Iowa can get pretty cold sometimes, and for the little effort it takes to change antifreeze, it's a lot cheaper than replacing a cracked block, head, or radiator....
Old May 7, 2003 | 10:29 PM
POO's Avatar
POO
Default engine ice
we can i get this stuff
Old May 7, 2003 | 10:35 PM
BigBadScrambler's Avatar
Default engine ice
nccracing,
Engine Ice replaces the antifreeze and is suppose to reduce the engine temp by 50 degrees. Pruple Ice and Water Wetter are products that you add to your coolant. Both are very good. I use Purple Ice and love it. Only requires about 2.5 onces for my radiator.
Old May 7, 2003 | 10:37 PM
Default engine ice
POO,
Engine Ice should be available at some ATV dealers as well as Rocky MT ATV. Water Wetter and Purple Ice are available at auto parts stores.
Old May 7, 2003 | 10:42 PM
nccracing's Avatar
Default engine ice
Thanks BigBad, I will have to try some out...My pred runs hot pretty quick.
Old May 7, 2003 | 10:51 PM
pudljumpr's Avatar
Default engine ice
So which is better? Engine Ice says it reduces temps by 50 degrees...what about water wetter and the purple stuff?? I visited those links BigBad, and the water wetter had a bunch of techincal stuff that went over my head, and the purple didn't say what it's cooling properties were... Any other opinions or experience??
