Help, need info on front wheel seal!
Old May 8, 2003 | 11:49 AM
sbishop664's Avatar
Default Help, need info on front wheel seal!
96 Xplorer 400...notice all the fluid in the hub assembly is gone....well first I notice all the fluid on the floor. the inside of the rim is also full of fluid.
How easy is it to change the seal? what tools do I need? THANKS FOR ANY HELP!
Old May 8, 2003 | 02:26 PM
OffRder15's Avatar
Well, you need the proper size socket to remove the nut inside the hub casting (I forget what size). Then you have to take the bearings out and totally remove the whole hub assembly...all this after you took the wheel off of course. [img]i/expressions/face-icon-small-smile.gif[/img] You will notice more bearings inside also. If you are not familiar with how it goes back together make sure you line the parts up on a paper towel. The seal is stuck into the black hub casting...you can't miss it. You will need a torch to heat it up and something to pry it for removal.
Also, take a look at the wear sleeve, that is, the part that the seal seats on. If there is a groove worn deep into it, you will need to replace that also, which I can't stress enough, because if you fail to replace a bad wear sleeve, you'll be doing this all over again in a few weeks. If you need to do the wear sleeve, you will need a gas/oil resistant sealant. If you have to replace the sleeve, let me know and I can help you a lot more.
I think I covered basically most of the stuff you need to know. If I said something wrong or forgot something, someone let me know. If you want me to scan the instructions from the repair manual, let me know. I will also have to check the torque on the axle nut, I am not sure of how many rolling inch pounds.
Old May 8, 2003 | 02:53 PM
sbishop664's Avatar
Thanks...I will give it a shot tonight..I did find some intructions with torque spec.! if I have any problems...I will post them
Thanks again!
Steve
KimSJoh
14
Jul 18, 2015 07:20 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
Coryco
Jul 6, 2015 07:30 PM
jettman
Jul 6, 2015 12:16 PM
