What is the Magnum 330 85 lbs heavier than the trail boss
Old May 8, 2003 | 11:46 PM
BarelyLegal's Avatar
Default What is the Magnum 330 85 lbs heavier than the trail boss
Tires are a bit bigger, front rack, low range and shaft drive doesn't seem like it would add up to 85 lbs more weight. Anything else you guys can think of to make it weigh 85 lbs more?
Old May 9, 2003 | 12:15 AM
biggin's Avatar
Your big ****[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 9, 2003 | 03:02 AM
Wow, you must be very educated. If you can contribute to society like you just did to my post this will be a third world country in no time.
Old May 9, 2003 | 07:22 AM
upnort's Avatar
The mag is built heavier starting with the frame. All those extra parts add up. It is more of a utility machine to do heavier things where the trail boss is more of, as it says, a trail machine. Totaly different body styles.
Old May 9, 2003 | 09:15 AM
Farmr123's Avatar
Heavier frame, dual racks, low range, heavier skid plates are a few reasons that pop into my mind.
Also, shaft drive adds a few pounds, and the machine is 'bigger' overall.
They are just designed different. The TB is more of a runabout or trail riding machine, while the Magnum is stouter because it is designed for work. In fact, except for being slow, the 330 Magnum may very well be better suited for real work than any other machine in its class (under 350ccs)
Farmr
Old May 9, 2003 | 11:34 AM
biggin's Avatar
OUCH!!!!!!!! I was kidding. A few more folks like me and the Iraqis will have to give the USA some aid.
Old May 9, 2003 | 01:28 PM
Yeah biggin. Cool comments but my *** is not THAT big. [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 9, 2003 | 09:08 PM
kblazk's Avatar
I'm surprised it doesn't wheigh more, don't get a magnum unless its 4x4, just get a boss.
Shainasmash
May 8, 2017 06:38 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Anomers
Aug 16, 2015 11:06 AM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
