Sp 600 Cooling Fan
Old May 11, 2003 | 11:51 PM
dcatt's Avatar
Default Sp 600 Cooling Fan
Went on a ride Saturday on the new 600, and it performed great, but I noticed that the cooling fan kicked on quite a bit. The temperature was around 75-80 degrees and we really weren't going that fast through rocks and mud. Is this normal? It may be normal, that's just what I'm asking. This is the first water cooled ATV that I've owned, so I really don't what to expect, as far as the cooling fan.
Thanks[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 12, 2003 | 12:10 AM
rootbone's Avatar
Did you check coolant level in the recovery tank ? also new engines tend to run on the warm side while breaking in, if no high engine coolant temperture symbol on info center came on your probably alright, be worried when fan never comes on, if ridding at slow speed in low range fan will cycle on and off alot.
Old May 12, 2003 | 12:12 AM
Lightman02's Avatar
I used to have a 500 and it did the same thing. Even though your going slow through rocks, your still putting alot of strain on the motor to climb the rocks. So it's normal for the quad to heat up and the fan to come on alot.
Old May 12, 2003 | 12:25 AM
Polaridoo's Avatar
My '02 700 does that too and everything is fine. Also, so do the other 600's in the group of guys I ride with.
Old May 12, 2003 | 12:27 AM
bearthunder's Avatar
Keep an eye on your coolant recovery tank, w/new machines it's not unusual
to have to add some coolant. Enjoy your machine[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 12, 2003 | 12:23 PM
lovemud's Avatar
I've got 100 miles on my 03 600 and and the fan still comes on all the time, this weekend it was 60 deg. at a steady 20 mph I could still hear the fan kick in every once in a while. Makes you wonder if the radiator is too small or doesn't get enough air.
Old May 12, 2003 | 12:42 PM
Snowride's Avatar
Very normal. Once the engine has reached it's operating temp, the engine coolant thermostat will open (176 degrees) and allow the collant to circulate through the rad. The fan temp switch comes on at 180 degrees which is very close to the cracking temp of the engine coolant thermostat.
Old May 12, 2003 | 05:56 PM
Polarisman3210's Avatar
Motors run hotter at slower speeds cause you aren't moving any air across the motor to cool it.
Once you get the bike up to atleast 15mph, it cools back down.
Running the fan while going slow, and going about 20mph does the same thing.
Old May 13, 2003 | 11:25 PM
dcatt's Avatar
Thanks guys for the info. I thought that wasn't nothing to worry about but I though that i would run it past everyone and see what yall thought.
Thanks again.[img]i/expressions/face-icon-small-happy.gif[/img]
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
