Taotao main-ex 110cc oil change question?
Hello to all,
I just purchased a taotao ata110-h atv for my son and I wanted to change the oil in it. It is automatic and when I looked under the engine there are two plugs that are the same. The guy I purchased it from really didn't know much about them so that is why I'm asking on this forum. Any help is appreciated. Also, Is there some place that I can get a user manual for this atv. thanks Philip
Maybe you can find the difference of these two plags/bolts interms of their sizes. One is sized for 17 wrench and the other is for 14. The oil drain is the one sized for 17. If you mistakenly loose remove the 14 sized bolt, some organs such as a coil-spring and a pipe with sevral holes will come out . These are components for cam-chain tensioner. Never loose 14 sized bolt. Good luck.
http://forums.atvconnection.co...ViewFullsize.cfm?ID=12
Thanks for the help, I'll try that. I need to look at them again because I thought they were the same size. Your link would not pull up but thanks again. On another note, do the automatic transmission use any gear oil or is it lubricated from the engine oil? Thanks
The engine oil of 0.7L poured would work for the lubrication to the transmission gears as you stated. I usually use Honda G1 oil, because the China engines are designed basing on that of Honda SuperCub as you may know. The link I pasted had not begun to work yet. I just wanted to introduce a photo which showed of the drain location. It's alive now. I haven't got used to use this WEB yet. Sorry, PHILIP0812
Here is a video http://www.motorxtremes.com/kids-atvs/oil-change.html I also just got taotao 110 for my kids i got it for $450 shipped. There is a shop here in albuquerque that wanted $800. It seems to be good so far.
There should be two drain plugs, one slightly on an angle and one strait down.
the one strait down is the oil drain bolt. the other one is the oil filter/screen bolt and that too needs to be removed and cleaned every other oil change.
I recommend a synthetic oil like Amsoil 0w-40 after the first oil change to help keep it running cooler and lasting longer
Gio Taotao 110 fluids
Trying to check the chain case oil on a new 110 quad. I popped the 14mm drain plug out and a spring and a little bit of oil came out. Do I need to top this back up? Is there more oil that I need to add other than motor oil? Should I do an oil change right off the get go? Brand new but heard the stock oil is junk. Brand new buggy for my kids. Want to make sure everything g is where it needs to be. Thanks.
