04 polaris sportsman 500 ho
If the top ends have been done right,could be a frozen one way check valve located below the oil lines on the engine causing problems. Has a plug, spring and bullet valve.Cheap 5 buck manual can help and is shown under lower engine rebuilding,plus other checks you can do. 2004 Polaris Sportsman 500 Service Manual PDF Download
Then there has to be a reason why the pistons are doing this. Scoring of pistons on the intake side can be from lack of lubrication or too much clearance allowed on the cylinder bore and sometimes air leaks,similar to what happens on a 2 stroke piston.And these pistons have super tight clearances if you look at the manual. Top end may be getting oil,but bottom end may not be.That's' why I said to check the one way valve Several people have had problems with these. Look at the oil flow chart also.Plus did you check oil pressure before the first piston failed? Should be 20psi at 5000 rpms if the oil pump is ok.
